I never did have much patience...
I'm awaiting the next batch of etches so have been investigating the next big thing. As some will know I've been looking at ways to productionise the Jenkinson carriage construction methods as a route to getting affordable accurate styrene carriages; hopefully without the faff that's associated with cutting umpty-ump nominally-identical windows out of a sheet of styrene. Well, we're nearly there.
Cynric was a great advocate for laser cutting, but when discussing it with him it became apparent that it posed some problems when this approach is used for carriage building, for a start the material is much more expensive (you can't use styrene sheet as it doesn't laser cut cleanly) and it's much more rigid (so tumblehomes become tricky). Over the last eighteen months I have therefore been looking at alternative methods and after some extensive, targeted research have just ordered the means to produce these carriages and a lot more besides: I will shortly be taking delivery of a CNC die cutter.
In no particular order this gives me the opportunity to produce low-cost, accurate, repeatable examples of the following sorts of items:
Carriage parts, from a sheet of panelling to a whole coach.
Painting masks, both self adhesive and stencils.
Patterns for pantograph mills/engravers
And goodness knows what else which occurs to me as I grow in to this new capability.
I'll be very happy to take enquiries if you have a ticklish job that would be made easier with pre-cut parts, whether it's one of the above or something completely different. I see no need to stick to model railways either; I'm sure my mum will have producing parts for dolls houses once she realises what we can do.
Over time I will be releasing kits of parts for various SR and constituents carriages, which is where the above panelling diagram came in. First off the blocks will be an SECR corridor brake composite (birdcage) and the experimental ex-SER re-framed coach now preserved on the Bluebell railway.
Without too much deep thought I can see we could get in to new sides for G1 Mk1 carriages, replacement sides for Slater's Maunsell carriages, companion vehicles for the G1 'Dee' project loco, panelling to back-date existing vehicle kits, masks for two-tone grey freight locos and their logos, double arrows, etc, etc.
More will follow in due course, but I suspect we'll be back to gearboxes and hornblocks for the next 'news' post...
JB, Yes, I'd hope so!
