DavidinAus
An update: in the end I took the advice from those of you who said that I really needed to check that all the compensation mechanism was moving freely (thanks Peter, and others), and then as I took the inner chassis out of the outer tender farm I realised that I could use a variation on Steph's and Martyn's (3-link) advice. If I introduced a spacer/washer between the outer and inner frames where they are screwed together I could introduce a reversible (but potentially permanent) twist in the chassis.
It seems to have worked!
The compensation mechanism was not entirely free to move, and I unsoldered the pickups and freed the centre left wheel some more. They now all appear to move up and down freely.
I introducing a spacer at one corner between the outer frame and the chassis, thus effectively applying a permanent twist to the latter. Now on my granite, the wheel was only about 0.1mm in the air at worst. Is the correction enough, I wondered?
So with every finder and toe crossed, I reassembled as much as was needed to allow the tender to run, and .... it now runs, as shown below! A horribly crude test, and of course it isn't crossing pointwork, but at least this is progress:
I realised that as it is the front wheels lifting off the track that creates the problem, testing the tender on the S-shaped curve but with a dip in the track might not be good enough: the concavity of the track might keep the front wheels in contact when flat track or even a hump in the track might have the opposite effect and cause a derailment.
So instead I had to raise the centre of the test track and make the tender run over this. The only realistic way to do this is to pull it behind the locomotive! So this became the first trial runs of the locomotive and completed tender:
It doesn't run smoothly - this is because there are electrical short-circuits created between the pony truck wheels and the front locomotive steps, and also between the guard irons on the tender (they are realistically close to the rails, too realistic, and will need to be shortened a fraction). However the assembly never derails, which for me is a triumph!
My thanks to everyone for their suggestions. I am wary of declaring "Mission Accomplished" a la George W Bush, especially as I haven't either tested it over points or even fully assembled the tender as yet, but it is looking much more hopeful than ten days ago.
David
David
