Even at this stage there are mistakes to be made, and lessons for others to learn from, perhaps.
For those who see these things there are several problems with the above locomotive.
Most obvious is the water-based varnish covering the letters and numbers.
Perhaps less obvious is the lack of window-glass.
Least obvious (perhaps) is the fact that the central two pairs of driving wheels in the second picture are
not exactly on the rails ....
In order.
I have had trouble with solvent-based varnish destroying transfers in the past, so once my "Fox" transfers were in place I fixed them with RailMatch water-based matt varnish, with the results shown in the pictures. This in itself I did not see as too much of a problem, because I thought that once an airbrush-applied coat was put on, the streaking would vanish.
My mistake, though, was to use a short-cut and (thinking that the varnish already there would protect the transfers) I used a "Testors" aerosol "dullcote" varnish on the tender sides.
Do not try this.
Whilst the transfers survived, it produced bubbles and wrinkles in some of the plain paintwork!
Incidentally, I don't yet know what varnish I should use. Perhaps dilute the RailMatch water-based varnish?
Disaster. They were large enough patches that, even allowing for my intention to produce a weathered appearance, I could not leave them as they were. I didn't want to have to do the whole sides all over again, so rubbed off the sections of affected paintwork with a glass fibre brush, back to n/s metal, then resprayed with primer, masking the letterwork.
Then I resprayed with matt black.
It isn't perfect by any means, but after weathering I don't think the differences will be visible.
Next the windows.
Initially I wanted to use microscope coverslips to make real glass windows, and even bought a tungsten scriber to cut the glass. however I soon realised that the coverslips were incredibly fragile, and I thought that in my hands would soon be broken in place on the loco., when replacement would be very difficult. Also I realised that there was no way to produce the front-facing windows on the cab from glass, anyway. Whatever method I used, I realised that the front windows were going to be impossible to position without taking the cab roof off. So rip it off I had to do (well, carefully unsolder and lift it off ....).
Using plastic "glass" was OK until I was unwise/uneducated enough to use cyanoacrylate to glue the side window frames in place. Araldite had been fine to secure the plastic sheet to the frames, but cyanoacrylate has made some of the glass go "misty". Well, I suppose there may have been quite a bit of steam in the cab at times ....
So, don't use cyanoacrylate near clear plastic, or it soon will not be clear.
Finally the problem with the wheels.
Once again, this is probably something a more experience model-builder would have avoided, but bear in mind that this is the first tender engine kit that I have ever made - three tank engines and a Garratt before this.
This illustrates the problem, and my solution (so far - I haven't fully tested it yet!
The MOK kit comes with a drawbar which has a disc at one end and an elongated disc at the other (running-track shaped). Naively, I went for the close-coupled length.
It looks good, and would work well on straight track, but on curves the tender will not articulate enough with the locomotive, and one or other comes off the track. The problem was that I had cut off the extra length of the elongated end of the drawbar. So I have had to reconstruct it from flat brass strip and solder it onto the drawbar, as shown. With a slot at the tender end, I'm hoping that the tender can look realistically close to the engine itself when pushed together, but will move apart enough to go around 2m radius curves when in forward motion. We will see eventually if this works!
So, when choosing a drawbar length for a tender engine, bear in mind the radius of the curves it will need to traverse. Don't "burn your bridges" until you've tried it on the track.
Incidentally, those who have followed this thread may notice something has changed in the pictures. My sons were worried that me using their pool table for pictures might end up in disaster to the green baize, and so we have now constructed a wooden top for the table! Time made by our recent weather - Australia really is a different world of weather. It is still warm, but we've had over 150mm of rain in the 5 days, and so plenty of time for making things like table-covers - and model locomotives, of course!
David
