Peter Cross
Great start. All the new layouts started makes me want to get on.
I know you have been toying with it for ages. I always have doubts too. Mostly with my own abilities.
What angle are the points you are using.
Same as me then. With a couple of A5s in the yard for space. Some said to use B8s but they were just too long.
If you put a piece of packing between the board ends before soldering the rail into place... then cut the rail... the gap between the rails after removing the packing is pretty small. For example, if you use an Xacto saw blade then most of those blades are circa 12 thou thick and hence using 10th plastic sheet for the packing gives you a 2 thou gap after the job is done.
Thanks Chris,
From the length given for the C&L points, I won't gain any saving in space by using those.
I'm wondering if it may be worth taking a look at Marcway points, and adding cosmetic chairs.
