Does that mean all rain will stop at the Tamar and Devon will remain sunny at all times?
In closure of the etched windows, these are in the post to Chris this evening.Thanks to all for suggestions and offers of help - what a great forum this is.
I did persist with bastardising the etched mesh and managed to get this far:
Considering a few days ago I thought this was a window option too far for me, I think it's come out OK.
I'm going to leave it to harden up before adding the remaining woodwork and replacing the roof. The original roof came off with the usual tool abuse as I decided it would be easier to install the windows to the balcony base and build up.
It's been a battle and I certainly wouldn't want to do many like that by the method I've used. Etching would definitely be the preferred option there.
I'm talking to Mickoo off-thread about the possibility of etching other metal framed windows in a certain large building I started in 2013. Thanks to Mick for his offer.
There's two to explore different bar thicknesses, both worked fine, that on the right being 0.05 mm narrower, could probably have gone the same amount again and they would of been okay for strength and etching, but maybe too thin for the real thing? To me the one on the right looks just about right.
Those etchings look very nice. I'm wondering whether they are cast iron frame, rather than leaded. Our village hall had a large cast one.
Very nice - if they are intended to be leaded windows then I'd be tempted to coat it with some solder cream and run a soldering iron over it just to make it a little more "3D" with a thin bead of solder.There's two to explore different bar thicknesses, both worked fine, that on the right being 0.05 mm narrower, could probably have gone the same amount again and they would of been okay for strength and etching, but maybe too thin for the real thing? To me the one on the right looks just about right.
Just park a van in front then...
Hi Chris,
Can I just ask if you have a particular technique for applying the York lazer cut roof tiles? Do you apply them in long strips or smaller sections?
Just started applying some myself and they're sticky little bu@@ers aren't they!
Matt
Those close up shots certainly show that the methods used stand up to close scrutiny. It will look great when painted and weathered.
Magnificent work chap. They are perfect.
