1366
Enough muppetry!
time for a win
the slide bars were finished on the miller last night before going to see Soft Machine in Canterbury. Fabulous musicianship, though I found a couple of the tracks a bit impenetrable, a bit too jazz for my taste.
Anyway, they need cleaning up, and a little filing here and there, but we now have two locos’ worth.
So as MrsD was off to a tennis tournament (neither strawberries nor Wimbledon weather!) I had the opportunity to make more noise.
I’d borrowed a steel packer from work, so with a 2.5mm hole drilled through it, I put a drill in the miller chuck, lined it up, and then clamped the block at a known location. A trial run on a bit of plasticard required a couple of goes, to correct a typo (I was lucky, they can be expensive!) and double check everything before doing the front rods for my 1361 ST.
These went well, so I stripped the rods off Chris’ Pannier, and did them too.
the bore is actually nice & crisp, the reflections confuse the iphone camera. Needs no more than the fluff cleaning off. Now I need to turn up a new pair of bushes and with a bit of luck, the most difficult bits of this build will be sorted.
This little machine is proving useful!
And Scotland waiting for the decision… no try, unbelievable.
time for a win
