Osgood
Well I didn't know so I had to investigate!
It's a single-piece (solid block with bored hole) bearing or support block - often used as a budget bearing, but in this case they are being used to support an axle which is prevented from turning by locking screws located in the block where you might expect to see a greaser.
Note the wheel with bronze bearing rotates on the fixed shaft.
Ah, something else learned today!
