Thanks Rob,
I tried like that, but with the floor. That was very messy, not doing that again
( Actually quite interesting, lots of semi-cured-not-very-well-stuck-together layers, a bit like an underdone lasagne - don’t ask!)
It would be easy to remove the floor and copy your approach, and of course, the subsequent join lines are in the corners inside, so trivial to hide.
You appear to have about 60 very fine supports along the edge. I’d need about 90, I guess, if we assume the absolute spacing is the objective. They don’t look like Chitubox tapered fine supports, did you generate them in the CAD? I think that might be quite easy to do - indeed, probably easier than the Chitubox approach.
I've spent too long on the ‘puter today, need to do something else, but this might be the way to go. Thanks
S
![ROFL :)) :))](/styles/default/xenforo/smilies/roflmao.png)
S
