….The company that does the cutting can supply 3mm MDF. This is useful and as a brick width is 2.62mm I think I can use the Gov's method of a comb join at the corners. ...
Do you have a link to a description by the Gov on WT, Phil?
I've just tried searching for 'comb joint' and drawn a blank but would be very interested in learning more on how to do this successfully.
Of courseFancy doing a couple of hundred factory windows?![]()
Nice toy to play with - I'd be interested to hear about the power and speed settings you use. I have access to a FAB lab in Manchester where I can use one but I can only book 1hr slots. So any recommendations on settings would be appreciated so I don't waste my allotted hour finding out what works.The settings I have to play with are laser power and speed. A combination of these is used to get the engraving/cutting level right.
Power down, and speed up and I think I'm getting there.
It would be ok to cut out the apertures but the detail would need an etch I would think. If you have a coach side and want the windows cut out then yes it would do it. Might be a help with big coach conversions when combined with window etches.What about coach &/or loco windows, Phil ?
Steve![]()
Happy to share the settings Adrian but not sure they will be necessarily any use for your machine.
I will be happy to cut any of your designs though.
