BrushType4
If no one closer can, I can always send you mine
Thanks Steve, I'm sure there will be one locally I can get my hands on.
Very impressive - in some ways I think an improvement, a bit more '3D' to it than a flat etching.So I bring you laser cut windows with openings
I was recently asked if I could design a building around etched brass windows. I said sure, but why not laser cut the windows so they match the prototype? The reply I received was that they didnt want lasered windows as they wanted windows that can be modelled with openings.
That could be a view from the inside - hence no brickwork detail?![]()
The weighbridge is a vast improvement on your prototype and really couldn't get any better (other than maybe holes for lifting eyes) - are you now able to easily process other designs for cutting (e.g. maufacturer's name, size etc)?
I thought about those, but was too lazy to do them. I'll add them inVery often they would open inwards supported on metal quadrants (basically a curved piece of metal, fitted to the top of the frame opening, on both sides).
Outside opening sashes could be top hung and have to have a straight top edge.
Col.
….Does this link answer that? http://intentio.co.uk/latest/
2 sets please Phil when your sorted...........Hymek & Crompton would be cool too
Phil
3 sets of Heljan 47 glazing when its ready please.
I made it as a separate component. I like the idea of a hinge but I think it would be tricky to pull off.How have you done that Phil? Is the opening frame a separate component, or have you not quite fully lasered through the hinge axis of the window, allowing the remaining ply to act as a hinge?
